I am looking to upgrade my system and would appriciate some constructive advice on where to start. Durring bench marks it seems that I am getting gpu bottle-necked. I mostly play games like Ark: Survival evolved and some platform types. Would like to keep my system relevant and capable of playing newer titles on med/high settings. I have a pretty tight budget and would have to save for anything over $300.
My system:
Core I7 6700
MSI Z170A GAMING M3
2x  CORSAIR 8gb ddr4 2400 (16gb total)
XFX RX470 4GB
Coolmax 900w PSU
SSD 120 gb SATA3
HDD 1 TB SATA3
COOLERMASTER HAF-XB
Windows 10
https://linustechtips.com/topic/1027443-system-upgrade-suggestions/
Used 1070ti
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
37 minutes ago, Dodeedo351 said:
I was looking at that and wondered how much of a performance boost would that likely give?
Looks up some benchmarks and find out.
The best bet is RTX 2060 at 349$ its gonna provide gtx 1070ti performance spend the extra 50$ and get RTX 2060 its 100% best bet but heres some options
For 1080p
gtx 1060 6gb
rtx 2060 (1080p/ 1440p) it can do great in both
1440p
gtx 1070
gtx 1070ti
gtx 1080
4k
rtx 2080
rtx 2080ti
rtx 2070
gtx 1080ti
Going from RX 470 to GTX 1070ti would almost double your performance.
Main System: EVGA GTX 1080 SC, i7 8700, 16GB DDR4 Corsair LPX 3000mhz CL15, Asus Z370 Prime A, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R5, 2TB Seagate Barracuda, 500gb Samsung 850 Evo
Secondary System: EVGA GTX 780ti SC, i5 3570k @ 4.5ghz, 16gb DDR3 1600mhz, MSI Z77 G43, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R4, 3TB WD Caviar Blue, 250gb Samsung 850 Evo
1070ti would be a great choice. And wouldn’t worry about lifespan. As the correlation between use and dying hardware is quite dumb and unmeasurable. Like brand new 2080ti’s must be dying from mining.
20 hours ago, Dodeedo351 said:
i'd just save 50 more for a 2060.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
