Hi all,
I am using a Hikvision security system model(DS-7604NI-E1 / 4P/A).  I have been trying to get my device setup so I am able to view it over the internet but I am having no luck.  I'm trying to run it through the ezviz website which I believe will allow me to gain access however my device always displays offline.  I am able to ping the device from my router and login into it remotely over the local connection.  I have attached a PDF file to show which settings I have chosen to configure my DVR with so if someone is able to see what I am doing wrong they can correct me to help fix this problem.
Thanks
Stealth
Hikvision.pdf
https://linustechtips.com/topic/1027292-cctv-help/
