Hello, I am a fairly new builder with only 1 build of experience. I just finished a new Z270 build. Specs-
MSI Z270 M5 ENTHUSIAST GAMING
Intel Pentium g4600
3x4 Corsair Vengeance C14 2400mhz ddr4
Pny GTX 1060 XLR8 (3gb)
Cooler master Masterbox Lite 5 RGB
Thermaltake TR2 500w PSU
WD Blue 250gb HDD
Corsair H80i GT w/ Coollaboratory Liquid Ultra
I am experiencing a problem, when I power it on, everything turns on, but the DRAM light is on (means missing or faulty ram), and detects the RAM, but no post, beeps, nothing. I have moved it to a box test-bench style, tried each individual stick, etc. And still get nothing. Any tips/ help?
https://linustechtips.com/topic/1027253-new-build-ram-problem/
Starting with one stick insert it into the DIMMA2 slot like the manual recommends, repeat this step with each stick to find if one stick is dead. If they all work like they should then proceed to follow the manuals instructions for installing more than one stick. For the third stick you have a 50/50 chance of getting it right.
https://linustechtips.com/topic/1027253-new-build-ram-problem/#findComment-12244382
