[ASK] Which is the best case for Huawei Mate 20 Pro?
So, i just got mate 20 pro and dont have a case, yet. So far, i found 2 cases that was said good at other phones, and easy to find here. It's Spigen Rugged Armour, and Ringke Fusion X. Please help me decide which should i buy and which is better.
EDIT: The important thing to consider is it durability and protection from drops
Thank you.
2 hours ago, Radioactive Snowman said:
If you want durability look at uag, they're built like tanks and can survive just about anything
Thx for the reply, but i dont really like that bulky look on UAG, so between those two, which is better?
Ive always had a good experience with spigen, so id go with that
