23 minutes ago, Timebandit150 said:
one for recording and the other for streaming
Captures Cards do not actually do any encoding work, you only need multiple cards if you're pulling from multiple sources.
https://linustechtips.com/topic/1027097-two-capture-cards/#findComment-12243077
