Posted January 28, 2019 GTX 980 ti or RX 580 8 gb ??? Link to comment https://linustechtips.com/topic/1026965-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 980ti if you can afford it ✧・゚: *✧・゚:* Quote for a reply *:・゚✧*:・゚✧ ✧・゚: *✧・゚:* Ask for discord *:・゚✧*:・゚✧ Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241702 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 980 ti, as it is about equivelent to a 1070. make sure your system can hold it tho Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241705 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 price? also which model specifically? CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241710 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 Yeah, what are your current specs? We don’t want you to get a 980tinif your system will bottleneck because of it ✧・゚: *✧・゚:* Quote for a reply *:・゚✧*:・゚✧ ✧・゚: *✧・゚:* Ask for discord *:・゚✧*:・゚✧ Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241717 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 Author 3 minutes ago, iLostMyXbox21 said: 980ti if you can afford it Yes i can sir. 1 minute ago, LukeSavenije said: 980 ti, as it is about equivelent to a 1070. make sure your system can hold it tho I thought so too. i5 4690k pushing it....so probably wont bottleneck, at least i hope so. Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241718 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 The RX 580 is a great card for 1080p gaming and it comes with 2 free games. If you can get the 980 ti cheap on ebay or something then its worth it. If you are spending anywhere near 300$ for it though (its price on amazon) you would be better going with the RTX 2060. Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241722 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 1 minute ago, milanvipa said: I thought so too. i5 4690k pushing it....so probably wont bottleneck, at least i hope so. not much, it's a fair combo what card and price are we talking about here? Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241725 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 Author 5 minutes ago, Jurrunio said: price? also which model specifically? About 220 eur / used. Reference. 3 minutes ago, iLostMyXbox21 said: Yeah, what are your current specs? We don’t want you to get a 980tinif your system will bottleneck because of it I5 4690k , 16 gb ddr3 hyperx fury , 750w psu , maximus hero VII , samsung 500 gb 860evo. Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241729 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 1 minute ago, milanvipa said: 750w psu may I ask which one specifically? Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241735 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 Author 2 minutes ago, Sorenson said: The RX 580 is a great card for 1080p gaming and it comes with 2 free games. If you can get the 980 ti cheap on ebay or something then its worth it. If you are spending anywhere near 300$ for it though (its price on amazon) you would be better going with the RTX 2060. Meh , wont buy new one's ever ...used one's are my thing...kinda used to those. Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241737 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 Author 1 minute ago, LukeSavenije said: may I ask which one specifically? Corsair RM 750x Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241742 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 Just now, milanvipa said: Corsair RM 750x oh good... at least that can't go wrong could you show us the listing of the 980 ti? Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241747 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 Author 1 minute ago, LukeSavenije said: oh good... at least that can't go wrong could you show us the listing of the 980 ti? The one that is refference card i got an offer from a friend, since he is going for a 1080ti ....his offer is 220 eur. I got another in check which is from MSI and its going at 250 eur , but i contacted the seller and he got me a 230 deal, and offered to give me 30 try-out days if something goes potato. Kupujem-Prodajem is our local Ebay https://www.kupujemprodajem.com/Kompjuteri-Desktop/Grafi-ke-kartice/GTX-980ti-u-rangu-ili-bolja-od-1070-72457310-oglas.htm Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241764 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 11 minutes ago, milanvipa said: About 220 eur / used. Reference. so it's reference RX 580 (I dont think it ever existed) versus MSI 980ti Gaming? Then it's MSI all day everyday. CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241778 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 2 minutes ago, milanvipa said: The one that is refference card i got an offer from a friend, since he is going for a 1080ti ....his offer is 220 eur. I got another in check which is from MSI and its going at 250 eur , but i contacted the seller and he got me a 230 deal, and offered to give me 30 try-out days if something goes potato. Kupujem-Prodajem is our local Ebay https://www.kupujemprodajem.com/Kompjuteri-Desktop/Grafi-ke-kartice/GTX-980ti-u-rangu-ili-bolja-od-1070-72457310-oglas.htm so fe? gaming (x?) is a good card, so you can choose either in my opinion through it is false that it is faster than a 1070, because it isn't Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241782 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 2 minutes ago, LukeSavenije said: through it is false that it is faster than a 1070, because it isn't depends on whether you leave both stock or overclock CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241795 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 Author 2 minutes ago, Jurrunio said: so it's reference RX 580 (I dont think it ever existed) versus MSI 980ti Gaming? Then it's MSI all day everyday. my "reference" was about 980ti ...not 580. Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241797 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 Just now, Jurrunio said: depends on whether you leave both stock or overclock true, but still it's made better than it actually is Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241802 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 1 minute ago, milanvipa said: my "reference" was about 980ti ...not 580. but the link you gave shows an MSI Gaming cooler... 7 minutes ago, milanvipa said: The one that is refference card i got an offer from a friend, since he is going for a 1080ti ....his offer is 220 eur. I got another in check which is from MSI and its going at 250 eur , but i contacted the seller and he got me a 230 deal, and offered to give me 30 try-out days if something goes potato. Kupujem-Prodajem is our local Ebay https://www.kupujemprodajem.com/Kompjuteri-Desktop/Grafi-ke-kartice/GTX-980ti-u-rangu-ili-bolja-od-1070-72457310-oglas.htm I guess this isn't your friend's post? But anyway I'd definitely pay extra 30 eur for the better cooler and PCB. CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241812 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 Author 1 minute ago, Jurrunio said: but the link you gave shows an MSI Gaming cooler... I guess this isn't your friend's post? But anyway I'd definitely pay extra 30 eur for the better cooler and PCB. My use scenario is some dota 2 , League of Legends, AC Odyssey...so all in all =gaming. Maybe some streaming on twitch in future...? I linked the MSI card which i am looking at , but my friend offering me 980ti reference for 220...i think MSI is worth those 10 eur more and hassle about shiping. I have decided that i will go with 980ti either way, honestly grow tired of AMD GPU's...have been using 7970 dc2 top...for about 2 years now. Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241836 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2019 4 minutes ago, milanvipa said: My use scenario is some dota 2 , League of Legends, AC Odyssey...so all in all =gaming. Maybe some streaming on twitch in future...? I linked the MSI card which i am looking at , but my friend offering me 980ti reference for 220...i think MSI is worth those 10 eur more and hassle about shiping. I have decided that i will go with 980ti either way, honestly grow tired of AMD GPU's...have been using 7970 dc2 top...for about 2 years now. The thing is that RX 580 just isnt as fast as the 980ti, it's only comparable to the 980. Definitely dont get the reference 980ti if you can, a 250w GPU doesnt like blowers. CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/1026965-help/#findComment-12241858 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
