Hi! I am building a bluetooth speaker. I already bought necessary parts (BMS, Boost Converter...) and I am planning to use my old bluetooth headset as an HID device, but at the output it gives 5-9V and i am wondering if this Audio Amp can work with audio at this voltage.
Audio Amp:
https://www.amazon.com/gp/product/B01MG48YK0/ref=ask_ql_qh_dp_hza
P.S I thought about finding where the Amp was on the headset, but couldn't find it.
Thanks in advance!
https://linustechtips.com/topic/1026937-audio-amp-problem/
The Louvre
Lian-Li PC-O11 DW   |   ZOTAC RTX 2080   |   Core i5 9600k   |   SeaSonic FOCUS Plus 650W Platinum   |   MSI MPG Z390 Gaming Pro Carbon  |  2x16Gb TRIDENT Z ROYAL  |   2xSX8200 240Gb NVME SSD's  |   1x Seagate Firecuda 1TB   |   EVGA Closed Loop Cooler 280mm   |   1x MSI MPG27C Monitor
https://linustechtips.com/topic/1026937-audio-amp-problem/#findComment-12241456
Just now, CharminUltraStrong said:
Well, that thing costs double the entire project.
Also i live in a pretty bad place for electronics standpoint and https://store.edison.ge/ this website is the only place where i can get them
https://linustechtips.com/topic/1026937-audio-amp-problem/#findComment-12241470
yep that is a language I definitely can not read. Well, the board you linked COULD work. You can always return it if it doesn't.
The Louvre
https://linustechtips.com/topic/1026937-audio-amp-problem/#findComment-12241484
