hello everyone I have a PC Optiplex 780 SFF, and q8400.I was researching if you can use the Xeon processors on this pc and I saw that if you can. I downloaded an update and updated the BIOS correctly, but now I can not use my q8400, I have disabled the option of cpu support that, serves so that the Xeon is compatible. I have the A15 BIOS, and now I can not use my q8400.It is on the screen that the cpu is not supported by the system and that it consults the documentation of the computer, I can not enter Windows. I know that is my error, but I want to know if this BIOS disables the core 2 quad, in order to buy a Xeon once, since I have seen that if you can use here, for example x3363. Thank you
https://amp-reddit-com.cdn.ampproject.org/v/s/amp.reddit.com/r/pcmods/comments/8lxp73/dell_bios_mod_for_xeon_cpus/?amp_js_v=0.1&usqp=mq331AQECAEoAQ%3D%3D
https://linustechtips.com/topic/1026489-please-help/
