As in the picture one of my 2 200mm intake fans on my H500M has stopped working. Initially both stopped working but when I unplugged the bottom one from the splitter the top stated working again. What ever I do when I plug the bottom fan it stops the top from spinning. I even tried plugging the bottom one direct to the MB but nothing happens.  the case is 2 weeks old ?
https://linustechtips.com/topic/1026057-intake-fan-issue/
Well if you tried connecting it individually and it does not work, then i guess the fan is dead, defective...
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1026057-intake-fan-issue/#findComment-12234183
Well got in touch with Box.co.uk who supplied the case and they want the whole case back. 2 hours to put together for a £16 fan. Told em I'd send em the fan but they were adamant they needed the whole thing.
  Absolute nobs know full well it's not worth the time and effort disassembling and reassembling the PC.
   I have reached out to Coolermaster but they don't make it easy with their ticket system broken.
  For now iv put the black 140mm I had spare from the exhaust on the front with the other RGB 200mm one....which looks nice ?
   And to top it off iv had a peek in Coolermasters spare parts store and the fan I need is out of stock.
https://linustechtips.com/topic/1026057-intake-fan-issue/#findComment-12240808
They(Box.co) want the whole case so they can send it back to CoolerMaster for a Replacement or money back, just how it works.  Better go buy more fans and spares Incase but I would RMA it.
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
https://linustechtips.com/topic/1026057-intake-fan-issue/#findComment-12242855
