Hello I had been having this problem with my graphics card (I think this is the cause). Basically when I was running games on my pc my monitor randomly would go black and the pc would try to restart itself, my graphics card (fans still spinning) would make an electric cutting out sound and the LED would cut out. The LED would then turn on only to be cut off again. The cycle repeated like this until I turned the power of with the psu. I tried doing downgrading the driver and that seemed to take care of the restarting problem. Except I was getting freezes in games. After a while I installed a 2 tb hard drive and unplugged the cable to the gpu, when I plugged it in again I’m guesing I used to much force because when I started the pc the graphics cards LED didn’t even turn on. I reinstalled the graphics card and it worked but I can’t remember what happened after that. One day after not using my pc for a bit of time I decided to download a game, after downloading I played for about fifteen minutes and then it did the restarting thing. I turned of the psu and tried to restart the pc but this time I couldn’t get to the home screen before it restarted. And when I tried again didn’t even turn on. I have tried reinstalling the graphics card like before but it leads to the same result, as in those three restarts. Any ideas?
Specs
Ryzen 5 2600
rx 580 used
psu be quiet 80+ silver (3 months old)
https://linustechtips.com/topic/1025970-graphics-card-problems/
All this writing and you didn't bother writing what is your GPU........
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1025970-graphics-card-problems/#findComment-12233461
