Budget HDR 4k monitor?
Bljuzga
23 minutes ago, Bljuzga said:
Anyone tested this yet?
Monoprice 32 inch 4K HDR IPS Ultra Slim Desktop Monitor, Gun Metal with Slim Bezel with UK adapter https://www.amazon.co.uk/dp/B07DVT8SKK/ref=cm_sw_r_cp_apa_i_0pYrCbV0RCX9D
Seems like a good deal
Not bad for its price
I think one of my friends had this monitor and he liked it.
There are no reviews on amazon uk yet this is what they say in the description:
  • Ultra High Definition: This 32" monitor features a maximum resolution of 4K@60Hz (3840x2160p@60Hz), giving it stunning, high resolution detail.
  • FreeSync Technology: The DisplayPort inputs support AMD� FreeSync� technology for a smooth, tear-free gaming experience when partnered with AMD video cards.
  • High Dynamic Range: The high-dynamic range video allows you to enjoy the beauty of a wider and richer range of colors, much brighter whites, and much deeper, darker blacks.
  • VESA Compatible: The adjustable stand can be removed to allow access to the 100x100 VESA mounting points for mounting to a wall or desk mount.
  • UK Plug, no adapter necessay for use within the UK"
I think I used to hav that monitor it worked great.
How can you not be sure, I would assume you change monitors frequently then. I personally only had two from 2002-2019 ?
They also have a ultrawide for 450usd + free shipping to Eu or at least I've checked for Ireland.
Here is the link:
https://www.monoprice.com/product?p_id=31005
Would be awesome if Linus would review these two monitors because info online is very hard to find and there are no reviews on youtube
These are the specs of the ultrawide:
Model 31005
Screen Size 35" (889.8 mm)
Active Area 32.3" x 13.6" (819.4 x 345.9 mm)
Maximum Resolution 3440 x 1440p @ 100Hz
Viewing Angles (H/V) 178° / 178°
Response Time (GTG) 5ms
Brightness 300 cd/m2
Contrast Ratio 2500:1
Dynamic Contrast Ratio 500000:1
Number of Colors > 16.7 million
Speakers 2x 5 watts
Stand Tilt Range +13° / -3°
Input Power 24 VDC, 3A
AC Adapter Input Power 100 ~ 240 VAC, 50/60 Hz
Maximum Power Consumption 72 watts
Standby Power Consumption ≤ 0.5 watts
Dimensions (without stand) 32.8" x 14.9" x 2.8" (834 x 377 x 72 mm)
Weight (without stand) 18.6 lbs. (8.45 kg)
seems a bit heavy, if i get the ultrawide not sure if my monitor arm can hold it, possibly if i tighten it real hard
