Hi,
I've recently played Witcher 3 on my PC, medium/high details at 50-60fps. Averything okay. No I've purchased Witcher 1 Enchanced Edition from GOG, but on high settings games runs at 15-20 fps. GPU usage stays around 16-30% and CPU at 25-30%. GPU doesn't even kick into higher GPU clock speed, stays at around 700MHz (max is 1189MHz). Newest Nvidia drivers, other games work as usual. What's wrong and what can I do bout that?
OBR CTM S.A.
https://linustechtips.com/topic/1024178-witcher-1-running-very-poorly/
Try disabling the environmental sounds in the game settings or setting the affinity of the process to 1 core. This game is known to run like a certain substance.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
Witcher 1 is not very well optimized, especially on newer hardware. Try the suggestion above by tikker, but I am not sure what else you could do. There might be a bunch of mods or fixes posted online for performance or something, just search and see what you find.
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
Its a 2007 game, it's not optimized for current GPU. It maybe using just a little of the gpu power and capped the performance so it doesn't go bananas.
If it's not capped you maybe seing 500fps and AI running like they haven't poop in a week.
I've seen a bunch of mods, but non of them (as of now) seem to run on Enhanced Edition and it'a common issue in modding community in my research. You know any place I can find some mods to help me and not break the game :).
OBR CTM S.A.
Seems odd, I played through that after beating TW3 as well and haven't had any issues. Have you looked/asked on GOG? They tend to do pretty good with making sure all their games run on current systems. Could even try their support page.
As to the game itself... I highly suggest you don't play it. It's awful.
#Muricaparrotgang
Thanks, just reported this issue directly to GOG :).
OBR CTM S.A.
