I am in python 3.7 and am trying to import console, but it keeps throwing up an error.
ModuleNotFoundError: No module named 'console'
What is this module called now?
Systems:
Main Gaming:                                                        Windows XP:
Ryzen 5 2600                                                               Intel Pentium 3
Asus RX 580 OC                                                     1GB DDR2
Patriot Viper DDR4 8GB                                         Asus Motherboard
Asus ROG B450-I                                                   Dell 300W
Corsair CX 450                                                       ATI Rage 128 Fury Pro
FreeNAS Server:                                                   Windows 98/95 duel boot:
I5 3400k        Pentium Pro
Patriot DDR3 8GB                                                  HP Vectra motherboard
Gigabyte Ultra Durable                                           500MB RAM
Rosewill Glacier 600W                                           Soundblaster 16
        Matrox Mystique
Random PC:
AMD Phenom x4 850                                          Key:
Kukete A78                                                          Motherboard
Kingston 4GB DDR3                                            Memory
Dell 500W                                                            Power Supply
        Graphics Card
Other Gaming:                                                    Sound Card
Ryzen 5 2600                                                       Processor
Asus ROG Strix B350-F Gaming
MSI 1050 OC
Hyper-X 16GB DDR4
EVGA 750 B2
https://linustechtips.com/topic/1024131-python-problems/
You need to install the console module. If you have the 'pip' package manager installed (usually is installed with python), then type 'pip install console'. If you also have python 2.x installed, then you might need to try 'pip3 install console'. (It's possible you might also need to run it as sudo if on linux if it throws an error)
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/1024131-python-problems/#findComment-12216422
