Behringer Vs Audio Technica
First of all let's get this straight, these are sub $20 micophones so i wouldn't expect much in terms of like actual sound quality.
Not being rude but most sub $20 microphones aren't that great.
however behringer does have a reputation in making some great budget mic's for around the $50 price range.
As to which brand is better.
Thats mostly comes down to personal preference.
They have both been in the audio game for years.
so in my opinion there isn't really a definitive answer.
as for what is the best choice for you?
i would go online and check out reviews, sound tests and recordings.
compare them, what do you hear what do you like.
like for example:
Behringer:
is it bright or moody
how loud is the output, does it have excessive noise etc etc
do that for both microphones and pick what would fit best in your scenario.
i hope this was helpful
Current build: Ryzen 7 1700x, asus prime x370-pro, 16gb gskill trident z rgb, asus rog strix gtx 1070 ti, corsair rm650x, nzxt s340 elite, samsung 840 pro 256gb, 1.5tb hdd.
I woudlnt put much into the brand to decide which is better (unless its 'Beats' or some such), especialy at that price range. best to just go by reviews.
if u want a more dedicated forum to ask on i sugest headfi
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Is there a way to put like a small piece of foam around the mic to act as a wind sock? ive seen that before but i do know it wouldent greatly, but improve sound quality it would help a bit.
Not sure about you but I think my 7 year old CPU still rips
Only really helps if you're got the mic to close to prevent the pfft sound of speaking in. Also makes them look a bit nicer, I personally didn't notice any difference when I worked in industry, but I mainly did lighting soo...
I make intelligent lights do cool things
