First build
Go to solution Solved by YaBoiWill,
whatever you do, DO NOT, and I cannot stress this enough, follow the verges PC guide.
If you haven't seen it, don't, death entails.
Its possibly the worst advice I have ever seen been dished out.
Actually go watch it to see how not to do it, but only after building your PC
Pretty wide array you're looking for.
Theres plenty of beginners building videos, paulshardware has a really great one for post build and windows/software set up.
https://linustechtips.com/topic/1023864-first-build/#findComment-12213879
I make intelligent lights do cool things
https://linustechtips.com/topic/1023864-first-build/#findComment-12213889
They deleted that video quite a while back.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1023864-first-build/#findComment-12213891
Sadly.
That was comedy gold
https://linustechtips.com/topic/1023864-first-build/#findComment-12213899
11 minutes ago, Slottr said:
Sadly.
Wayback machine to the rescue. Pretty sure others will have copied it and posted it somewhere (hopefully because its a laugh to watch)
So....
Probs against all of the guidelines of the forum as its basically a pirated video, but, here it is.
I still cant get past the thermal paste bit.
https://www.youtube.com/watch?v=rE9Y454Cg-E
https://linustechtips.com/topic/1023864-first-build/#findComment-12213913
Thanks!
Bruh, that was like anti pc propaganda ?
https://linustechtips.com/topic/1023864-first-build/#findComment-12213987
