Okay, here's the thing: I have an old Acer Aspire T180 at home from 2006, came with a Windows Vista OEM, has an AMD Athlon 64 X2 Dual Core, a MB with 4 DDR2 Memory slots, 2 occupied by a 1GB DIMM each, OS upgraded to Windows 7 Ultimate last year. The PC was working perfectly, until, somewhere last July, I rebooted it after installing a security patch, and then, after the reboot, where it was supposed to post, the CPU fans just stopped spinning and I had NO picture whatsoever on my screen. I tried pretty much EVERYTHING at this point (CMOS Battery reset, rebuilding the PC from scratch, switching up the CPU fan plug socket etc.), AKA I pretty much warranty voided every single part (not that it matters, no one produces these parts anymore). And since I am not the only one that uses this PC ( I only deal with hardware maintenance, software, drivers etc) and the other person uses it for office work, I am in a pretty bad hurry right now. Please help me!
Thanks in advance!
You could try booting into the BIOS with no drives and/or fewer RAM sticks. But if you can't get it to POST at all, you may need to just replace the machine altogether.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
Nope, not even the BIOS starts up. And I've tried several Hard Drives (also SSDs) with different Windows versions installed (also a W2G drive) and well..... nothing But good idea. I'll think about replacing it but I will still try to get it working. I still have hopes for that machine. Thanks though.
Dunno. I didn't check that yet. Good tip though. Also Eastman51 the PC that you listed on PPP is WAY over my budget. I just need a PC that WORKS but also not pre-built. IF I buy a new one. Right now I am more looking for a way to repair that old one IF there is one. I hope there is.
Always quote people when you try to tell them something because otherwise they probaly won't even see that you responeded to them. You can quote somebody by clicking the big arrow under their post
