will dual channel work?
Go to solution Solved by Jurrunio,
yes, settings follow the worse performing stick.
Desktop benching:
https://linustechtips.com/topic/1023659-will-dual-channel-work/#findComment-12212405
10 minutes ago, Yuvraj Mann said:
will i be still able to get those extra fps during gaming?
depends on whether you're memory bottlenecked
Desktop benching:
https://linustechtips.com/topic/1023659-will-dual-channel-work/#findComment-12212426
