How to fix mic on hyperx cloud alpha.
rekt1
Hi, so suddenly my mic on the hyperx cloud alpha was not working on my discord and windows after i updated windows 10. Pls let me know if there r any possible solution to fix this problem thanks.
In the sound on control panel go into sound then recording and make sure your mic is selected as default.
1
mine is alr at deafult device
In sound once again, double click on your mic, then in microphone properties go to levels and make sure that your mic is at a reasonable level.
it is alr and also what do u mean by reasonablecus my volume is 100 with a 20 boost
  • 1 year later...
