Im looking to build this PC in the next couple months, as I order parts...
a couple questions,
...is the 2080ti's price so high because they are sold out right now? or is this the price point they will always stay?
...is there a better monitor that would go more along with this PC setup? im not that good at monitors
any help would be greatly appreciated :)
https://linustechtips.com/topic/1023164-build-help/
What is this thing for?
I'd rather get slower memory, worse motherboard and less memory for another 2080ti
Desktop benching:
https://linustechtips.com/topic/1023164-build-help/#findComment-12208446
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  ($529.89 @ OutletPC)
CPU Cooler: Cooler Master - MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($154.99 @ Newegg Business)
Motherboard: Gigabyte - Z390 AORUS MASTER ATX LGA1151 Motherboard  ($239.99 @ Newegg)
Memory: Corsair - Vengeance RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  ($114.99 @ Newegg Business)
Storage: HP - EX920 512 GB M.2-2280 Solid State Drive  ($89.99 @ Newegg)
Storage: Toshiba - X300 4 TB 3.5" 7200RPM Internal Hard Drive  ($118.85 @ OutletPC)
Video Card: EVGA - GeForce RTX 2080 Ti 11 GB Black Video Card  ($1196.98 @ Newegg)
Case: Fractal Design - Design Define R6 USB-C - TG ATX Mid Tower Case  ($119.99 @ Newegg Business)
Power Supply: Corsair - HX Platinum 1200 W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($109.99 @ Newegg) overkill but the same price as it's 850w variant.
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  ($124.79 @ OutletPC)
Monitor: Acer - ED7 34.0" 3440x1440 100 Hz Monitor  ($478.68 @ Amazon)
Total: $3279.13
Generated by PCPartPicker 2019-01-18 21:48 EST-0500
https://linustechtips.com/topic/1023164-build-help/#findComment-12208470
Total: $3279.13
What would you recommend for a 27” monitor? I’ve had 32+ inch and they just seem to big for me. I’d rather have 2 27s or even just one.
https://linustechtips.com/topic/1023164-build-help/#findComment-12209331
can try this:
https://pcpartpicker.com/product/ttnG3C/acer-monitor-xb271hubmiprz
https://linustechtips.com/topic/1023164-build-help/#findComment-12209393
1 hour ago, Manderis said:
What is your plan with those 3 m.2 ssds? Only get one boot m.2 and the rest can be sata. If you don't plan 3 way raid 0 there is no point.
Also 1200 W psu? A bit overkill imao. 850 W would still be plenty.
@Manderis I was looking to do raid 0 with the three m.2 Also the user that gave me the build, said the 1200w psu was the same price right now as the 850w. because in the future I may look to do NVLink with another 2080ti
https://linustechtips.com/topic/1023164-build-help/#findComment-12209812
Why raid 0? Do you have any specific use case that would profit from that or just for the lulz? And you are right the 110 $ are an OK price.
But be aware that you might have poor efficiency running your pc in idle. Did not find a specific efficiency curve for that psu though, just a general thing.
https://linustechtips.com/topic/1023164-build-help/#findComment-12209859
2 hours ago, birdwarrior said:
raid 0 is unnecessary, the single EX920 will be fine.
https://linustechtips.com/topic/1023164-build-help/#findComment-12209931
honestly I have no use cases, other than just raw speed, but I don't need the sata ports really on the mobo other than maybe one for the 4TB HD, and a fan connector.
https://linustechtips.com/topic/1023164-build-help/#findComment-12209933
https://linustechtips.com/topic/1023164-build-help/#findComment-12210040
https://linustechtips.com/topic/1023164-build-help/#findComment-12210048
Just now, XxEpicFortniteFanxX said:
Definitely bro I was in ur shoes and needed help like this when building my pc 5 or 6 months ago so I am glad to help
yeah I have a bachelors in IT when it comes to networking and hardware.. but when it come to gaming Im out of the loop. What setup did you go with?
https://linustechtips.com/topic/1023164-build-help/#findComment-12210074
2 minutes ago, XxEpicFortniteFanxX said:
I was on a bit of a budget so I had an 8700k and a 1070ti and it runs great but I would have loved to do what you’re doing. Props man I don’t have the self control to save that much money.
Haha, yeah my Job offers unlimited OT, so I can save this much in about a month time.
https://linustechtips.com/topic/1023164-build-help/#findComment-12210080
