@The_Big_Grape In the nicest possible way: If you have no idea what you're talking about, don't try to offer help.
@ifunnnn Make sure you've turned phantom power on when you're using the cloudlifter. Despite the sm7b being dynamic the cloudlifter needs phantom power to work. There's a switch on the back next to the power switch. Be careful that you've not got anything plugged into the mic inputs that would be damaged by phantom power as it's applied universally to channels 1-4.
https://linustechtips.com/topic/1023130-help-please/#findComment-12208240
Hello!,
Yes I don’t know what I was talking with the mixer about but no one was helping so I just tried as much as I could to help. I mostly know about computers but just tried to help!
Hope you have a great day though! :)
Thanks,
The_Big_Apple
https://linustechtips.com/topic/1023130-help-please/#findComment-12208386
