Its just a normal cable as you are saying in the tittle
DP to HDMI.
(i have one myself)
There is also an adapter DP to HDMI.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1022883-dp-to-hdmi-cable/#findComment-12205681
If you're using more than one monitor, you may need an active adapter. One like this https://www.amazon.com/Cable-Matters-DisplayPort-Supporting-Technology/dp/B00EDT0072
Otherwise, the cables do exist https://www.amazon.com/Cable-Matters-Unidirectional-DisplayPort-Adapter/dp/B004C9P9TM
https://linustechtips.com/topic/1022883-dp-to-hdmi-cable/#findComment-12205755
DP to HDMI.
(i have one myself)
Allright, thats what i needed to know. So i can just plug it in and thats it? One monitor is already plugged in into HDMI on the graphics card, hopefully that wont be the issue.
https://linustechtips.com/topic/1022883-dp-to-hdmi-cable/#findComment-12206955
As I said, if you have more than one display, you will need an active adapter. Both myself and @circeseye linked to active adapters.
https://linustechtips.com/topic/1022883-dp-to-hdmi-cable/#findComment-12206975
Yeah, seen that, but you sad i may need the adapter, so i  would like to get away with just the cable ?? Will get the adapter, pretty much all of them work fine?
https://linustechtips.com/topic/1022883-dp-to-hdmi-cable/#findComment-12206993
(I was trying to use better English)
Like I said, the adapters myself and @circeseye linked to will work fine.
I have four monitors running as we speak. I tried to get away with just a cable, and that didn't work for me, but the active adapters did.
https://linustechtips.com/topic/1022883-dp-to-hdmi-cable/#findComment-12207005
Thanks man, appreciate the answers, adapter it is!
https://linustechtips.com/topic/1022883-dp-to-hdmi-cable/#findComment-12207993
