I have a 32gb intel optane module, when loading the optane software, I have this message appear "no compatible disk for intel optane memory" (picture attached)
i cant see it in device manager or the bios either.
but if i download intel ssd toolbox, i can see it there but not able to erase it. (picture attached).
i have checked all the bios setting and all the good, i have an msi motherboard that has optane genius on it and have even tried running this.
i had it running when i 1st rebuilt the system the other week, then i decided to install water cooling system so took all apart, problem started when it was all put back in.
i have tested it on another system and had no problem with it.
system running:
windows 10 pro
msi z370 sli plus
i7 8700k
asus strix 1070 x 2 (sli)
corsair vengeance 32gb ddr4
  • 1 month later...
On 1/17/2019 at 6:41 PM, flyingpingu said:
problem fixed after 2 hours on the phone with intel, somehow my windows version didn't have the correct inbedded drivers.
What drivers exactly?? Im having this issue, I had optane running just fine for 9 months and now this just happened and all my setting and everything is correct
