I found this not sure if it works but this is the closest thing I could find.
UGREEN USB Card Reader USB 3.0 Hub 3 Ports with SD TF MS M2 Card Adapter and Phone Stand Dock Combo for iMac, MacBook Pro Air, Macbook Retina, Mac Mini, Windows Surface Pro, IdeaPad, PC, Laptop,Tablet https://www.amazon.com/dp/B01N5FWIDS/ref=cm_sw_r_cp_api_i_.dNqCbJ76CSQ0
2 minutes ago, ErikReb said:
Thanks for these links. Is USB 3.0 speed enough, i think not.
USB 3.0 can transfer around 300MB/s in tests I've done. Whether or not that is fast enough for you depends on what your needs are.
As for your original question... Lexar makes a 3 slot reader (https://www.amazon.com/Lexar-Professional-Three-slot-microSDHC-microSDXC/dp/B012PQM9HI). If you're wanting to offload 20 cards at the same time, you're likely going to have to either make something yourself or have someone custom build you something. Option 3 I guess buying 7 of those lexar units, a USB hub, zip ties, and some 3M double stick tape...
There's no place like ~
Problems and solutions:
FreeNAS
Dell Server 11th gen
ESXI
