4 hours ago, Lexseroth 17 said:
My laptop wont power on and when it's plugged in it won't charge. Tried removing the battery but it still wouldn't work.
It's either one of two things happening.
1: The power brick has failed and needs to be replaced.
2: The input plug on the laptop has broke and needs to be repaired.
I have had both happen on the past. But number 2 is the more common to happen.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/1022055-no-charging-no-power/#findComment-12198146
The brick and port are dishing out power
https://linustechtips.com/topic/1022055-no-charging-no-power/#findComment-12202807
Most likely the plug connection inside the laptop is broken then.
Current Build
AMD Ryzen 2600
Stock cooler
1tb SKHynix m.2
WD 1TB HDD
Phantek fans
Phanteks P400TG
Laptop
Ryzen 7 5800h
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/1022055-no-charging-no-power/#findComment-12203230
