so im wanting to have sleeved cables for my corsair CXM 750 psu but i dont want to spend $80 for sleeved cables for a $100 psu. but Idk where to begin and how difficult it is i also want something to do so im not so bored but i also fear i may screw something up. so i was also think of seeing if i could pay someone on the forum to do it for me. which would be better doing it my self. or paying someone to do it but i want to know how much it will cost to get started and how hard it is. please help
also if you could make me a list with links of what i would need and where to buy them you get extra internet points
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/10218-help-sleeving-cables/
I would like them to look a bit like these
https://linustechtips.com/topic/10218-help-sleeving-cables/#findComment-110311
just hit up ebay or NCIX just need heat shrink, sleaving and a mod tool, its not hard to do just very time consuming and i doubt any1 in the fourm in there right mind would custom sleave cables for under that price :)
Plenty of guides on the youtubes even linus has a basic one wich will get you started.
[url=
[/url=
https://linustechtips.com/topic/10218-help-sleeving-cables/#findComment-110322
I just started sleeving myself and currently in the middle of my first attempt at it (case fans, front I/O, PSU). I ordered all of my stuff from ModDIY (sleeves, heatshrink, pin removal tool set, etc.)
http://www.moddiy.com/categories/Cable-Sleeving/?sort=bestselling
http://www.moddiy.com/products/modDIY-Black-Heatshrink-%280.6mm-to-22mm%29.html
http://www.moddiy.com/products/Sunbeam-Universal-Molex-Pin-Remover-%28Full-Set%29-.html
If you notice in the first link they have a chart of what size sleeve/heatshrink you will need depending on what you are planning to sleeve.
In quick...
individual wire sleeving: 3mm sleeve with 4mm shrink
case front I/O: 4mm sleeve 5mm shrink
sata cables: 10mm sleeve 12mm shrink
The prices are good and shipping to Canada is a reasonable rate. They have so much stuff I never knew existed. Will be posting a build log here once I'm done.
[Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16
[GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850
[Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 6x 120mm Corsair LL RGB
Theater Room - My 11.1 Home Theater
https://linustechtips.com/topic/10218-help-sleeving-cables/#findComment-111988
In quick...
i go to http://lutro0-customs.com/ they have everything and it is all hi quality and tested
https://linustechtips.com/topic/10218-help-sleeving-cables/#findComment-112037
Sleeving it's self isn't hard; however, getting everything neat and well done takes a very long time and can be a real heartache to do properly. Moreover, if you want to sleeve your PSU completely, you will have to void the warranty on it which isn't preferable. Have a look at buying sleeved cable extensions from BitFenix as they offer the same look, minus the danger involved.
https://linustechtips.com/topic/10218-help-sleeving-cables/#findComment-112557
nope i dont like them i want them to be custom colors also i already bought all the stuff needed
https://linustechtips.com/topic/10218-help-sleeving-cables/#findComment-112732
