So this is my first time ever when it comes to anything computer related.
I have an old pv which can hardly run games and i've been thinking on upgrading to something big.
All i know about PC's is self taught and i will appreciate constructive criticism.
I've been watching linus tech tips to help me understand and learn but i've come to a slight problem.
The build i'm planning to make is
CPU - Intel - Core i5-8600 3.1 GHz 6-Core Processor
CPU cooler - ARCTIC - Freezer 13 CO 4 CFM Ball Bearing CPU Cooler
motherbaord - MSI - H370 GAMING PRO CARBON ATX LGA1151 Motherboard
memory - G.Skill - Aegis 16 GB (1 x 16 GB) DDR4-2133 Memory
storage - 1 TB
GPU - Gigabyte - GeForce GTX 1060 3GB 3 GB Windforce OC Video Card
case - Carbide Spec Omega
SSD - 500GB
Power supply - Cooler Master MWE 600 Watt Silencio Fan, Modular 80 PLUS
Operating system - windows 10
I've used the site pcpartpicker.com and found out it miscalculated the watts the GPU needs.
 I've tured to this site for help and it will be greatly appreciated.
https://linustechtips.com/topic/1021680-help-a-newbie/
Honestly, don't get the 1060 3gb unless you really really need CUDA. Get the RX 580
Faster RAM would help a bit if can spare the change, and buy 2 sticks of RAM so that you can use dual channel memory. So instead of 1x16gb get 2x8gb
  • CPU
    r5 5600x
  • Motherboard
    Arous b550 pro ac v1
  • RAM
    Tcreate 32gb ddr4 3600 cl18
  • GPU
    1660 super
  • Storage
    SN570 1tb
  • PSU
    Corsair CX750
  • Audio
    Lots of chi-fi iems
  • Operating System
    Windows 11 (lastest)
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194339
how does dual channel memory work?
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194342
Just now, ViveLaVita said:
location is Israel so things are a little bit more expensive.
Buudget isn't really all that matter bucause i am planning to work for months for this thing. but i would say around 1600$ maybe even 2000$ if i really wanna get a beast for a pc
Holy crap, that's a lot of money. Get a 1080 with a decent cooler if you can find one that's not overpriced around 600 bucks should be good
  • CPU
    r5 5600x
  • Motherboard
  • RAM
  • GPU
    1660 super
  • Storage
    SN570 1tb
  • PSU
    Corsair CX750
  • Audio
    Lots of chi-fi iems
  • Operating System
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194344
Long story short, 2 sticks of RAM is like having 2 straws to drink from instead of one. This is not the best analogy, but it's kinda what it is
  • CPU
    r5 5600x
  • Motherboard
  • RAM
  • GPU
    1660 super
  • Storage
    SN570 1tb
  • PSU
    Corsair CX750
  • Audio
    Lots of chi-fi iems
  • Operating System
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194349
the thing is that the powersupply is already with me. i need to build the system around it/
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194350
How much 1060 3GB cost in Israel?
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194354
600 watts should be plenty
  • CPU
    r5 5600x
  • Motherboard
  • RAM
  • GPU
    1660 super
  • Storage
    SN570 1tb
  • PSU
    Corsair CX750
  • Audio
    Lots of chi-fi iems
  • Operating System
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194355
7 minutes ago, LukeSavenije said:
oh fun... I can burn down a build again
/jk
I see some problems and just things that aren't worth getting
what is your location, use and budget?
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194360
Then plan the build once you have the money. New stuff will come out by then, prices will have changed, and therefore recommended builds will change too.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194382
Just now, myselfolli said:
I'd definitely put more of my budget towards a better GPU. And probably more/faster RAM and more hard drive storage.
i have been thinking about going on the 2000$ budget and going for the GTX 1080 8GB with intel core i7-9700k
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194388
just some examples:
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194389
while this is a good idea, and i thnka you i simply at the moment i want to learn about PC's as well as to have a general plan for the future. i like to plan ahead
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194392
2 minutes ago, noxdeouroboros said:
Not that different from Europe. May I ask why you choose such mediocre parts which cost way less then your assumed budget?
i am building the pc from scratch except the power supply, so i need to buy everything needed.
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194398
50 minutes ago, LukeSavenije said:
just some examples:
oh wow! thank you so much! this is very helpful.
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194406
Still your initial setup according to that budget is really odd, much under budget of 2k. Well you have some options provided now, good luck with the build.
https://linustechtips.com/topic/1021680-help-a-newbie/#findComment-12194416
