What GPU, PSU and HDD do you already have? and are you planning on purchasing an SSD to use in this system?
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1021414-first-pc-build/#findComment-12191738
Type Item Price
CPU AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor $239.00 @ Canada Computers
Motherboard ASRock - B450M PRO4 Micro ATX AM4 Motherboard $77.63 @ Vuugo
Memory Team - T-Force / Night Hawk 16 GB (2 x 8 GB) DDR4-3200 Memory $159.99 @ Newegg Canada
Case Azza - Inferno 310 ATX Mid Tower Case $42.70 @ Vuugo
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $589.32
  Mail-in rebates -$70.00
  Total $519.32
  Generated by PCPartPicker 2019-01-14 16:53 EST-0500
https://linustechtips.com/topic/1021414-first-pc-build/#findComment-12191828
6 minutes ago, TMFN_WOLF said:
That looks pretty good
I don't like the logo on the side of the case, but it's cheap and the reviews aren't that bad. Looks like a decent case, otherwise. My next choice would be the cooler master masterbox lite 3.1, but I think the Azza has more fans and they look pretty decent. You could go a little cheaper on the RAM but then you start sacrificing performance.
Or if you don't need 16gb you can get 8 for now and upgrade later.
Edited by ChewToy!
https://linustechtips.com/topic/1021414-first-pc-build/#findComment-12191854
3 minutes ago, TMFN_WOLF said:
There is a Canada computers right by my house so i can go look at cases there
Okay, cool. I would definitely go with the 2600/2600X route, though, as you just can't beat the price to performance there and it provides a great upgrade path. There's really no point in spending money on Intel at the moment as it's just not cost effective and you're not gaining enough performance to justify the cost.
https://linustechtips.com/topic/1021414-first-pc-build/#findComment-12191887
