Iris Pro Bf4 will it run?
Go to solution Solved by voaz,
720 on low, med. No AA and other heavy settings: Will run on playable fps ( 30-45 );
So if I were to run Bf4 on my MBP, since it has Iris Pro graphics, I should be able to get playable frame rates at 720P easily?
Is this Iris Pro the same as the one in the NUCs and those that Linus showed off in the Iris graphics video?
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/102098-iris-pro-bf4-will-it-run/
720p at medium or low settings with no AA.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/102098-iris-pro-bf4-will-it-run/#findComment-1365548
Great, thanks! low settings are no problem :P
https://linustechtips.com/topic/102098-iris-pro-bf4-will-it-run/#findComment-1366578
Linus actually did a video with Iris Pro graphics and it was pulling off BF4 at Medium graphics, 1368 x 768 with 30fps. It is very impressive.
*Insert Name* R̶y̶z̶e̶n̶ Intel Build!  https://linustechtips.com/main/topic/748542-insert-name-r̶y̶z̶e̶n̶-intel-build/
Case: NZXT S340 Elite Matte White Motherboard: Gigabyte AORUS Z270X Gaming 5 CPU: Intel Core i7 7700K GPU: ASUS STRIX OC GTX 1080 RAM: Corsair Ballistix Sport LT 2400mhz Cooler: Enermax ETS-T40F-BK PSU: Corsair CX750M SSD: PNY CS1311 120GB HDD: Seagate Momentum 2.5" 7200RPM 500GB
https://linustechtips.com/topic/102098-iris-pro-bf4-will-it-run/#findComment-1367267
