Ok, so my cpu has been running at around 60 degrees Celsius idol. I just powered on my pc this morning and it at 23 degrees idol. I check the clock and that is still the same. I am running an AMD FX 6300 overclocked to 4.3ghz. Are the temps changing this drastically overnight a problem?
https://linustechtips.com/topic/1020950-cpu-temps-are-lower-than-normal/
60 idle is really hot, 23 sounds correct. What cooler are you using? And what software to check temps?
Primary PC:
PSU tier list
How many watts do I need?
Ok I think I figured it out, tell me if I may be correct. I checked my clock again and it was at 3.5 ghz which is not overclocked, so I think my bios might have changed it do to power limitations of my system? Is that possible? I have 2 dvd drives 3 HDD’s 4 sticks of ram a 1050 to plus an amd Fox 6300. My psu is 500w
i also just added in some of that stuff, forgot to mention it though
BIOS settings can be reverted sometimes, I'm not sure what motherboard you have but It's a known behavior. Can you simply reenable the OC settings?
Primary PC:
PSU tier list
I'm thinking the same too, BIOS settings probably got reset.
Also I'd recommend turning down the OC a bit (maybe to 4GHz) since 60C idle is pretty toasty. I'm not surprised temperatures have drastically improved with the OC off.
2 minutes ago, Ian Goppert said:
Yes I can, I think I’m going to keep it at 3.5 though, unless I’m wrong about that temp increase not being justified
if it was 60 idle, I wonder what the load temps were.
Primary PC:
PSU tier list
