DESPERATE Audio drivers
Go to solution Solved by m1cr0l,
Bios reset did the trick
I am really lost... I just got an MSI B450 Carbon Pro AC, everything was going great until  plugged in my headphones into the rear audio jack and I heard lots of static sound. I thought it was a driver issue so I reinstalled the audio drivers from MSI Website and suddenly the "Speakers" and "Realtek digital output" is missing in the Sounds tab. I tried reinstalling the drivers again but to no avail. So I reinstalled Windows from scratch and reinstalled all the drivers but they wouldn't show up. I am in desperate need of help right now, if anyone of you knows how to solve this issue please help. Thank you very much
https://linustechtips.com/topic/1020915-desperate-audio-drivers/
On 1/13/2019 at 7:02 PM, m1cr0l said:
How do I go about forcing a windows update? Via the settings then check for update?
For future, yes
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
