Ok so obs is being really fickle for me, when I turn on game capture, it only captures popular games like overwatch and undertale. But as soon as I want to stream a game like osrs or open Ttd, all I get is a black screen... do I have to capture it with window capture or something like that?
I am faster than 80% of all snakes
cpu: AMD Fx-8350
motherboard: GIGABYTE 970 (am3+)
RAM: 16gb ddr3 adata
gpu: AMD xfx rx 560 2gb
psu: 500w
storage: 1tb hdd
I am what you call “budget gamer”
https://linustechtips.com/topic/1020912-more-obs-help/
No, you don't, all that you have to do, is just open up the source thing, add window capture, or just capture your whole desktop, and it should show whatever window you select, which would work with every game, or it would just capture your whole desktop.
https://linustechtips.com/topic/1020912-more-obs-help/#findComment-12187483
Thanks! I will try that as soon as I come home
cpu: AMD Fx-8350
psu: 500w
storage: 1tb hdd
https://linustechtips.com/topic/1020912-more-obs-help/#findComment-12187491
