so I just finished building my computer and now im trying to install windows but im wondering whats the difference between the first and last options, im just confused because they both say theyre my usb.
(edit: also sorry if this isnt the right place for this, I wasnt sure where to post.)
https://linustechtips.com/topic/1020715-help/
2 minutes ago, Alexsolo said:
It's two different boot modes. The first being UEFI boot and the second being a Legacy boot mode (which is just the device name).
Here's some documentation to inform yourself: https://docs.oracle.com/cd/E23161_01/html/E37044/gnchj.html
I would just use the first option UEFI and read all Windows install instructions carefully.
Also PROTIP: unplug the 2 TB drive while installing on the SSD to avoid windows making unecessary partitions on the second drive. Once windows is installed and the PC reboots you can plug back in the 2 TB and initialize it from the disk management center in windows.
https://docs.microsoft.com/en-us/windows-server/storage/disk-management/initialize-new-disks
thanks man, very informative.
https://linustechtips.com/topic/1020715-help/#findComment-12185883
