Anyone know a software where i can change the blue colour that is displayed on the words zotac on my gtx 1070 zotac card
CPU: Ryzen 5 2600 @ 3.2Ghz
Motherboard: MSI B450 Gaming Pro Carbon AC
RAM: Team Vulcan DDR4 16GB (2x8GB)
GPU: Zoatac Gtx 1070 8GB
Case: CoolerMaster Masterbox Lite 5 RGB
Storage: 2TB Toshiba HDD, 120GB WD Green SSD
PSUGigabyte P650B
https://linustechtips.com/topic/1020397-gtx-1070-lights/
2 minutes ago, Shimejii said:
zotac has its own software more then likely
PSUGigabyte P650B
https://linustechtips.com/topic/1020397-gtx-1070-lights/#findComment-12182938
zotac calls it firestorm I believe
Desktop benching:
https://linustechtips.com/topic/1020397-gtx-1070-lights/#findComment-12182952
