I just purchased a brand new monitor. It works great, but the Freesync won't turn on in the osd and my Latest Crimson Driver says Freesync not supported. When I used the included hdmi, the Freesync was on @60hz
I'm using
RX 480 8GB to MSI MAG240VC via Displayport vesa certified club 3d cable (don't know if I spelled it right)
Windows 10 latest version and AMD drivers.
PSU 600w  80 plus
8GB dual channel ddr4
I5 6th gen
Any help would be appreciated
https://linustechtips.com/topic/1020348-freesync-not-supported/
did you enable it on the monitor settings?
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1020348-freesync-not-supported/#findComment-12182956
did you check radeon settings?
Edit: I see you did
Edited by Navid Jamali
https://linustechtips.com/topic/1020348-freesync-not-supported/#findComment-12186157
