Hi guys, I am planning to build my pc for the first time. Please take a look at the build and I would appreciate if you can tell me if it's ok. Also, since I can only connect to the internet through wifi, can anyone suggest a wireless adaptor that is not too expensive?
CPU: AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor  ($158.89 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($65.98 @ Newegg)
Memory: Corsair - Vengeance LPX 8 GB (1 x 8 GB) DDR4-2666 Memory  ($58.99 @ Amazon)
Storage: Samsung - 860 Evo 250 GB 2.5" Solid State Drive  ($52.99 @ Newegg Business)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 3GB 3 GB SC GAMING Video Card  ($199.89 @ OutletPC)
Case: NZXT - H500 (Black) ATX Mid Tower Case  ($67.10 @ Amazon)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.89 @ OutletPC)
Total: $708.62
Generated by PCPartPicker 2019-01-11 10:36 EST-0500
https://linustechtips.com/topic/1020100-first-pc-build/
Total: $708.62
I remember when this was me, you have fun now. But back on the system, what's your total budget? and what do you plan on doing?
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180331
Grab an RX580 instead of that 1060, can be had for $209...
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=rx580&N=-1&isNodeId=1
Microcenter has the Ryzen 5 2600 for $159 and then save $30 on bundling a motherboard too.  Or the Ryzen 7 1700X for $149.
https://www.microcenter.com/search/search_results.aspx?Ntt=ryzen
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180332
Total: $708.62
Try to get 2x4 stick of ram.
Main PC
i5-9400f @2.9GHz | Corsair H100i Elite Capellix |Gigabyte RGB GTX1060 6GB | Corsair CX650M | Island Professional 120GB SSD | Toshiba 2TB HDD | Corsair Vengeance RGB Pro 2x16 DDR4 3200MHz  | Corsair iCUE 220T | Windows 10 Pro | CPU R20 Cinebench Score -  pts | OpenGL FPS -  FPS | Novabench Score (OC) -  Base -
Keyboard and Mouse
Corsair K70 RGB MK.2 Cherry Mx Red | Corsair Glaive RGB
Streaming PC (HP Compaq 8100 SFF)
Xeon X3440 @2.53GHz | Radeon HD 6450 | HP Compaq 240watt PSU | Toshiba 1TB HDD | Samsung 2x4 DDR3 1333MHz | HP Compaq 8100 SFF | Windows 10 Pro | CPU Cinebench Score - 409 cb | OpenGL FPS - 16.77 FPS | Novabench Score (OC) - 991 Base - 938
Keyboard and Mouse
Logitech G413 Silver White LED Romer-G Switch | Old Gateway Mouse
Monitors
AOC - 21.5" IPS LED FHD Model - l2279VWHE | AOC - 24" TN Panel FHD 144hz 1ms Response - Model G2460PF
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180338
I think he should stay with Nvidia cards, Nvidia has better support and better drivers. And although i don't think that particular 1060 is a good idea i think he should perhaps go for the MSI GTX 1060 as it is one of the best cards out there and come with a factory OC and the best cooling in the market
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180342
Just now, Burnedice25 said:
WHY? having one stick is always better than having two! Having two takes away upgradability and makes troubleshooting harder. Plus its probably more expensive
unless this is sarcasm and I'm just being whooshed, dual channel memory is definitely worth it I'd say.
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180354
My budget is around $700 at most. I mainly play mobas like dota and some new games with medium settings.
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180356
Nvidia vs AMD is user preference I get it  Tho the RX580 8GB will outperform the 1060 3GB card.
But Ryzen loves fast dual channel RAM.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180365
Please explain! I have no idea why using two of your RAM DIMMs would be better than just using one. the MoBo he wants has 4 DIMMs and if he uses 2 of them for 8 GB of RAM then he only has two left to put more in later.
Maybe get a quad-core CPU and use that remaining cash to get a slightly better GPU and SSD. otherwise, pretty good
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180369
If you are saying that one stick is better. You don't know things about ram. Stop please stop arguing it. I upgraded from a 8x1 stick to 2x4 and I had atleast a 5 FPS increase in every game! Same i3 CPU. Its so worth it and if he does want to upgrade you don't really need more than 16gb of Ram for gaming in this day and age.
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180376
He's using a Ryzen processor, which performs best with dual channel RAM. If he wanted to later, he could put another 2 4Gb sticks (or more) in and have 16Gb RAM so I wouldn't say he doesn't have upgradeability.
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180377
Your points are all true, the 580 will outperform the 1060 but as I've already said, he can always get a better 1060 (MSI would be my go-to) and it would cost less for similar performance. he could use that extra money for a better SSD, as he is only playing DOTA and such and those games use very little GPU power
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180379
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.99 @ Amazon)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($99.99 @ Newegg)
Storage: HP - EX900 250 GB M.2-2280 Solid State Drive  ($46.99 @ Newegg) much faster than the 860 evo and cheaper.
Video Card: PowerColor - Radeon RX 580 8 GB Video Card  ($179.99 @ Newegg) performs better for less.
Case: Fractal Design - Meshify C Mini Dark TG MicroATX Mini Tower Case  ($69.99 @ Newegg)
Power Supply: Corsair - CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($32.98 @ Newegg)
Total: $699.81
Generated by PCPartPicker 2019-01-11 10:57 EST-0500
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180381
Total: $699.81
Herman pretty much nails it.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180389
Total: $699.81
Thats good.
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180391
if he goes for 1 stick, he will have the ability to go for 32 GB of RAM if he really wanted to. You are just cutting him off at 16, half of what I'm proposing.
Yes and no. RAM shouldn't directly affect FPS, the only way it does is if you run out of it while playing and since you got a 5 FPS to boost I'm guessing your either lying, got a fluke or misread something.
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180400
Just one example, there are many more...
https://www.youtube.com/watch?v=6sRsRyZIRTY
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180403
Total: $699.81
The only complaint I have is that its a MicroATX board and it doesn't have an Nvidia card (Which is my opinion, but the Mobo point still stands). but otherwise a really good build
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180406
he's only losing 3 pci-e slots with m-atx, not a big deal unless he can somehow justify needing more than 3 pci-e connectors.
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180413
I never denied it would give him better FPS on a Ryzen chip, I just said it wasn't worth the tradeoff for upgradability.
This is about single channel and dual channel RAM giving better FPS>  You did infact say he was lying.  Ryzen performs better with dual channel RAM, proven by testing as well as stated by AMD.  There's no way around it.  Dual channel is the way to go.
Btw, Herman's build allows for 32GB of RAM for the same price as his original build.  Done and done.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180432
True, But I think that a MicroATX board looks quite ugly in an ATX case, and yes I know you put a micro ATX case on the list, but I think he should swap that out for something he likes better. Cases are mostly aesthetic choices.
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180441
He said he got better FPS on an i3, not a Ryzen chip. I never said it wouldn't give him better FPS on a Ryzen. And i never said he was lying, just said he might've been
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12180448
Im not lying. There is a boost. Stop talking like you know everything when you never bench marked it
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
https://linustechtips.com/topic/1020100-first-pc-build/#findComment-12181735
