Alright so here’s the case
I just built my first pc
Ryzen 2700x
Rtx 2070 system
In nzxt h500 case
I’m using the stock cooler right now, but I’m looking to OC my cpu soon, so I am looking to put in a liquid cooler
My case can have one fan in back 120
One top 140 and up to 240 in the front
Back and top are exhaust, so can I just put a 240mm liquid cooler in the front and not have an intake,
or should I get a 140 mm liquid cooler for top and put one intake in the front
Or should change the back fan to an intake
What should I do?
https://linustechtips.com/topic/1019467-need-help-with-cpu-cooling/
Using the front panel as an intake while mounting your radiator there is still a very decent cooling solution, so long as you have good fans for the intake and exhaust via rear and top.
When I had my NZXT S340 Elite case (roughly similar case) I had my AIO radiator in the front with Noctua NF-F12 iPPC-3k fans in a pull config to improve airflow inside the case too. Compared to the stock cooler on my old Ryzen 1700, I saw huge improvements in temps across the board for everything from CPU to GPU to mobo temps.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
using a massive air cooler is not an option?
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
Use a 240 in the front, the radiator doesn't really hinder too much airflow so it shouldn't effect airflow in your case, especially if you get some fans with high static pressure that can really force some air through your rad
Do i Recommend Ryzen? Yes. All of the Yes.
Main Rig Specs - BIG BOI
Ryzen 5 1600 @ 3.9Ghz
ASUS Gaming TUF B450 Micro-ATX
2x4Gb HyperX DDR4 @2133
GTX 1070 Founders Edition
Corsair Crystal 280X
500Gb SanDisk Sata SSD, 1Tb 7200RPM Hdd
EVGA 500 Watt 80+ Bronze
EKWB A240
14 hours ago, wh0cares said:
thanks guys, this helps, follow up question, should i do push or full configuration for front intake with radiator
All depends on how the fans interact with your case specifically. Tentatively I would say pull so that the fans aren't between two different restrictive barriers which can hurt performance and it also makes it easier to clean the rad without taking the fans off. But the best test would be to mount them in a push and then try a pull and measure both thermals and see which one is louder. Some fans make more sound in pull vs push or may  make a buzzing when the blades pass by the struts of the case and less so when placed up against the radiator.
