Macbook Pro 2015 model not working on triple screen?
SoftwareNinja
Hi all,
I currently have my Macbook Pro wired up to 3 monitors all 1920x1080 in max resolution but it will only detect 2 of the 3?
The centre monitor is plugged into the main HDMI port on the laptop and then the 2 other monitors are connected via thunderbolt to HDMI Adapters.
Is there a way I can get the third monitor to work or am I stuck with just the two?
Thanks in advance.
I'm not sure about the HDMI version used, but since Apple lists
Quote
  • Support for 1080p resolution at up to 60Hz
I'm wouldn't be surprised if that translated to 2 1080p monitors at 30 Hz. It's a bandwidth issue.
You can try the Thunderbolt ports with adapters for more screen real estate.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
