I'm trying to pick a new power supply and this one looks good for what I need:
https://www.evga.com/products/product.aspx?pn=100-N1-0650-L1
but the CPU connector is a 8pin (4+4) those are two 4 pins that get plugged in side by side correct?
the image looks almost like its an 8pin so just want to make sure I've got everything I need because my CPU just needs a 4pin
https://linustechtips.com/topic/1019345-power-supply-question/
The 4+4 pins are made so they can join together if they're used into an 8pin power socket. But of course you can seperate them, thats why they're called 4+4. You'd end up with one 4pin connector dangling loose though. Perhaps you should look into getting a more modular model.
https://linustechtips.com/topic/1019345-power-supply-question/#findComment-12172847
https://linustechtips.com/topic/1019345-power-supply-question/#findComment-12172999
That PSU is garbage.
Why 650W?
And what other options?!
What does it power??
To be blunt: If you need 650W, you have the money for a high end Platinum one as the hardware needed for that is liker 1500€ for CPU, Board and GPU.
If you don't have the money for that, then you're probably fine with 400-550W and should get a higher QUALITY unit. Higher Wattage/Lower Quality units like the EVGA N1 are total nonsense.
Yes
But you must not get the PSU anyway...
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1019345-power-supply-question/#findComment-12173588
