All,
Currently I have my cpu and gpu in a loop with two 360 rads in my Lian Li O11 Dynamic case. The side rad is intake and the top rad is exhaust. There is no room in the bottom for fans due to my loop. There is however room in the rear for an 80mm fan. Could I run both rads as intake with the rear 80mm as exhaust? My thinking is this would allow for very little dust since both intakes are filtered and would allow for cooler air. Specs are i9-9900k, 1080ti, z390 Auros Master.
https://linustechtips.com/topic/1018073-best-aio-rad-layout/
