On 1/6/2019 at 11:23 AM, Mista G said:
Looking to replace the 3 standard fans that came preinstalled in my case, but what's the very best I can buy for high airflow?
Well. How much dBa do you have to spare? Because Industrial fans will sound like a hurricane, but they work wonders.
More seriously, the Noctua NF-A12x25 is the best fan on the market right now. https://www.newegg.com/Product/Product.aspx?Item=9SIAADY76X3131&Description=noctua nf-a12x25&cm_re=noctua_nf-a12x25-_-1YF-000T-000K7-_-Product
https://linustechtips.com/topic/1017969-high-airflow-fans/#findComment-12160354
Not too bothered about dBA in all honesty as I use a headset, although I suppose some silence is appreciated when without.
What would you suggest for excellent performance and some silence?
https://linustechtips.com/topic/1017969-high-airflow-fans/#findComment-12160382
The A12x25. It's the best fan on the market for a PC Case, minus looks. Can add a PWM extra fan controller if you want really tight control (if your motherboard has limited PWM headers).
If you want something a little lower down the cost range, be quiet!'s Silent Wings 3 series is very good. https://www.newegg.com/Product/Product.aspx?item=9SIA68V46Y1207
https://linustechtips.com/topic/1017969-high-airflow-fans/#findComment-12160400
After scouring the web I have come up with 3 possible contenders...
1. Corsair ML140 PWM Magnetic Bearing Fan
2. Noctua NF-P14S Redux PWM 1500RPM Fan
3. Noctua NF-A14 PWM 1200/1500RPM Fan
I'm leaning towards the more pricey Noctua NF-A14 purely for performance?
https://linustechtips.com/topic/1017969-high-airflow-fans/#findComment-12164064
You won’t go wrong with Noctua fan
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
https://linustechtips.com/topic/1017969-high-airflow-fans/#findComment-12165283
For performance alone, the ML140 is easily better due to being 2000rpm.
What are your specs?
https://linustechtips.com/topic/1017969-high-airflow-fans/#findComment-12166277
Phanteks Evolv Flow Edition Case + 3 140mm PH-F140SP 3-Pin Preinstalled
Corsair RM750x PSU
AMD Ryzen 5 1600X CPU
Noctua NH U12S SE-AM4 Cooler
Corsair Vengeance RGB Pro 2x8GB Memory
Gigabyte AB350 Gaming 3 Motherboard
Powercolor Red Dragon Vega 56 8GB GPU
Samsung 970 NVMe 250GB SSD
Toshiba 1TB Performance HDD
https://linustechtips.com/topic/1017969-high-airflow-fans/#findComment-12167092
The stock case fans should be pretty good already. Why replace them? Are your temps too high?
https://linustechtips.com/topic/1017969-high-airflow-fans/#findComment-12167102
Recently built my daughter a new PC and noticed it's getting fairly toasty after long periods of gaming, so I said I would replace her fans with mine and I'd buy replacements.
https://linustechtips.com/topic/1017969-high-airflow-fans/#findComment-12167177
How toasty? Temps?
https://linustechtips.com/topic/1017969-high-airflow-fans/#findComment-12167937
