what is framerate 1% low .1% low
Solved by Electronics Wizardy,
Its for showing the framerate of the worst 1% or .1% of frametimes. It basically shows how bad the low framerate is, the closer to the mean the better.
Basically if you line up all the frame rate numeres by frame rate, you pick the number that is 1% or .1% from the bottom.
You can also think of it as picking the frame rate that is 2.32 and 3.1 standard deviations below the mean
Featured Topics
Agall ·
Posted in CPUs, Motherboards, and Memory2 -
3
xKempo ·
Posted in Troubleshooting0 -
5
Dcorrigan97 ·
Posted in Troubleshooting1 -
Davidf4e ·
4
3
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
