CPU doesnt boost to maximum
Solved by X_X,
The default for that CPU is for it to run all cores at a maximum ratio of 36x which at 100MHz BCLK means 3.6GHz. 40x ratio is for 1 core active only, the other 3 cores need to be stopped at C-State 3 or higher.
Now there is an errata that allows Haswell to run all cores at full turbo, ie 40x ratio in this case but that requires one of the first BIOS revisions with pre-fix microcode, if it even exists or a modified BIOS.
