Hi everyone. First ever post on a forum lol.
So my problem is that my computer for the past few months has been doing this thing where I can plug everything in power, display, ethernet, USB devices and such. And when I power it on all the fans spin up lights turn on hdd spins up cpu fan spins up, and everything seems fine and dandy. But I don't get any output to a monitor and short pressing the power button if it was per say stuck in the bios would normally immediately shut it down but it does nothing even if left for awhile and long pressing it is the only way to shut it down short of flipping the psu switch.
Things I've done.
I replaced mobo, switched out ram, reseated cpu and gpu, tried different USB ports and even tried not plugging anything in as iv had USB not let a system boot before. But alas no luck. I have a feeling it is most likely the gpu that's bad or needs repairs what have you. But currently don't have the ability to buy a new one.
Mainly looking for troubleshooting tips that I may not have done yet or something I'm overlooking.
Specs are
Cpu, Amd fx 6300
Mobo, relatively new gigabyte board
Gpu, evga ssc 960
Ram, 16 GB cosair
Psu, evga 500 watt 80 plus
Any help would greatly be appreciated
Thanks in advance!
https://linustechtips.com/topic/1017288-pc-will-not-fully-boot-i-think/
Try a different PSU.
I've had systems where the PSU will die not completely, but enough to not power on a system beyond drives, fans, and lights.
If you can try a friend's unit, that's even better.
Just now, vetyatrez said:
@Crunchy Dragon
Never really thought about a psu only partially dying currently can't get to a different psu but will definitely try it as thats alot cheaper than a new gpu. Thank you for the help so far!!
I'd recommend a Corsair CX550M, those are pretty good units and can usually be found for in the range of 50 USD.
