Hello everyone. Recently i built a new rig (still work in progress) and i have issues with the cooling.
Here are relevant specs:
NXZT H700i (1x 140 fan, 3x 120 fans)
z390 Taichi Ultimate
i9-9900K (hydro 115i pro for cooler)
Asus 2080 TI Strix O11G (built-in cooler)
Problem is, the gpu gets really hot (funny enough, i have no issues with cpu despite all the bad press). So if i close the glass panel, it gets really hot inside the case and card eventually reaches critical temps when playing games. If i leave the side panel open, i can play for hours without issues (the card reaches 65° celsius max).
It is obvious that current set-up (see screenshot) is not working and i need to readjust/upgrade the cooling of the system so i would be able to close the side panel. Suggestions how i could do it are very welcome :)
https://linustechtips.com/topic/1017017-cooling-issues-need-new-plan-solved/
1 minute ago, brob said:
The top fans should be exhaust.
With the radiator of the CPU, and the front only intake fresh air
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Yes. General rule of thumb is bottom and front intake, top and rear exhaust. The goal is to establish a unidirectional airflow. The current configuration actually works against that goal.
you dont really have much exhaust, flipping the top fans might help
Builds:
You could try disabling the frontmost and/or front two top fans to see if either configuration improves gpu temps.
https://www.gamersnexus.net/hwreviews/3108-nzxt-h700i-case-review-better-if-it-were-dumber may offer some insights.
