Right now I have a H500m case holding a 2080 (triple fan) and a 9900k cooled by a clc 280. Currently the clc 280 is blowing air in through the radiator at the top and 2 200mm fans at the front are blowing air in. The only fan blowing out is the back 140mm exhaust fan. Is this too much positive air pressure and should I flip the clc fans to pull air out of the case? Which would be better for temperatures and in general?
https://linustechtips.com/topic/1016708-airflow-advice/
for minimizing dust build up without dropping cooling performance to the bin, your setup is ideal. If you just want performance then put the CLC 280 to exhaust.
Desktop benching:
https://linustechtips.com/topic/1016708-airflow-advice/#findComment-12149327
