hello guy. I had a problem with my fps a month or two ago. most of my game won't get fast 60fps. example: kingdom come 20fps, all total war game 30-40fps, assassin creed origin, and Odyssey  40fps. the only pubg still remain 100fps+ like before. I used to play total war at around 90 fps now it only 30-40fps. I already change my PSU to 850w and it doesn't seem to fix a problem. I already contact Nvidia, Asus, and Microsoft . microsoft told me that it my card problem because I had latest window version already. and Asus told me to install their driver and chipset I already installed it and still not work. nvidia told me that it can be my card issue because I already use DDU and clean install my driver they told me to do a video card stability test. but i dont get any error at all. my card alway run at 99% 1940mhz (factory OC) and temp is okay never throttle down. my cpu is running around 50% load and never throttle down too.
my spec:
i7 7700k 5ghz (stable) this problem had before i oc my cpu.
16gb of ram
gtx 1080 ti oc edition
270e mb.
my 3dmark score and heaven score are normal too. i don't think its hardware issue. please help guy I only had two choices left: reset bios to default and reset window. and my cpu is not parked.
https://linustechtips.com/topic/1016405-please-help/
