I recently Purchased two of these Cable Matters Blank Patch Panels, I was wondering what size ethernet keystones would fit in the patch panel? I want RJ45 to RJ45 Connecters, not RJ45 to Punch Down connecters.
If you need me to follow up on something, please quote or tag me.
https://linustechtips.com/topic/1016258-patch-panel-help/
You need Keystone couplers. I'm changing over to them myself. I bought punch down ones and just prefer the strength of terminated RJ45 ends to punch downs.
https://www.fs.com/products/41438.html
Like that (There's also monoprice, but haha, I like fs.com more)
https://linustechtips.com/topic/1016258-patch-panel-help/#findComment-12144971
Keystone modules have a rectangular face of 14.5 mm wide by 16.0 mm high and are held in place with flexible tabs. With that being said, it is OK to use any keystone coupler that fits the other network requirements you may have as they are all compatible.
fs.com is a great source for parts.
https://linustechtips.com/topic/1016258-patch-panel-help/#findComment-12148620
  • 2 weeks later...
Would I need Shielded Couplers, or will Un-Sheilded Work?
https://linustechtips.com/topic/1016258-patch-panel-help/#findComment-12196766
2 minutes ago, scottyseng said:
Are you using shielded or un-shielded ethernet cable? I wouldn't get shielded couplers for non shielded cables.
That was another question, should I get shielded or non-shielded cable, for IN-WALL use?
https://linustechtips.com/topic/1016258-patch-panel-help/#findComment-12196861
Get non shielded cable (at least ft1 rated in Canada not sure what the US equivalent is) and non shielded jacks. You should be fine keep you distance from electrical wires around 6" minimum. Try to cross power cables at 90 degrees when possible. If you can't it's no the end of the world. If you are planning to run the cable into some old 1980's variable frequency drive then consider shielded equipment. For regular home use unshielded will be more then fine.
https://linustechtips.com/topic/1016258-patch-panel-help/#findComment-12197405
On 1/15/2019 at 8:34 PM, scottyseng said:
Are you running next to any electrical wires? In any areas of high electrical interference? (Welders are pretty bad, etc)
Yes, this will be near electrical wires.
https://linustechtips.com/topic/1016258-patch-panel-help/#findComment-12204489
Ok, I will lookup code too.
https://linustechtips.com/topic/1016258-patch-panel-help/#findComment-12204491
US should be in wall is generally CL2 rated but again, double check for your specific area just in case.
Suggestion to use shielded near these if you can, also be sure that the shielding grounds somewhere or else it's pointless to have there in the first place.
https://linustechtips.com/topic/1016258-patch-panel-help/#findComment-12206513
How would I ground the cables?
https://linustechtips.com/topic/1016258-patch-panel-help/#findComment-12208173
The shielded cables have a foil liner and a ground wire, you need shielded RJ45 connectors and have the foil and wire contact the metal shielding of the RJ45 connector. It can be tough to get it installed correctly, but has to be done. Also have to check that the shield is actually connected from one end to the other.
https://linustechtips.com/topic/1016258-patch-panel-help/#findComment-12208255
