5 minutes ago, LukeSavenije said:
for the stock case fans and the corsair power is the same, the 4 pin fan headers. for the corsair you need a rgb controller to control the fans in colours properly
I need pwm control for The Corsair ML120 PRO 120mm Premium Magnetic Levitation RGB LED PWM Fan with Lighting Node 3 and fan hub but not for case fans
https://linustechtips.com/topic/1016006-fan-headers-incomplete/#findComment-12142920
pretty much yeah, pdm means it needs another pin (so 4 pin), but you can use a 3 pin fan on a 4 pin header without problems
your board has that header...
https://linustechtips.com/topic/1016006-fan-headers-incomplete/#findComment-12142978
So will using a fan splitter grant me pwm for Corsair fans ?
https://linustechtips.com/topic/1016006-fan-headers-incomplete/#findComment-12142984
1 minute ago, hackgod said:
Any nice splitter/hub ?
just a plain splitter if you want to control them all at the same time, hubs are kinda out of my knowledge, you'll have to research on that yourself, or ask a cooling nerd around here about it.
https://linustechtips.com/topic/1016006-fan-headers-incomplete/#findComment-12143019
Anything works. Only difference is that some hubs are packaged more nicely. Silverstone has well rated stuff, check if those are available for you.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1016006-fan-headers-incomplete/#findComment-12146703
