Case advice
Solved by NineEyeRon,
2 hours ago, Scorpio 72472 said:Oh yeah didn't notice that. Thank you
I'm in an ITX case with a 140 and 120 at the front. Same PSU and GPU types and a 120 at the back. Therefore slight positive pressure.
My GPU is right up against the PSU, pretty standard for ITX cases, it idles at 40 and loads at 65. A good case can overcome the issue of a GPU against as PSU like the above.
EG Fractal Design Nano C
