Specs:
5960x oc to 4.4ghz Water cooled custom loop
Asus x99 Deluxe mobo
64gig Corsair dominator platinum
2 evga gtx 1080it ftw3 water cooled custom loop
Corsair hx1200i power supply
I built a pc in late 2015 early 2016 and it is now giving me the cpu red light, been running perfect up until yesterday when it rebooted itself and then would not post. Its suck on Q code 04 with the red light on the cpu. Ive checked everything (pulled ram, power supply is good as all fans run, pulled all peripherals) Would you guys say the mobo is dead or the CPU?
Thanks!
https://linustechtips.com/topic/1015634-lil-bit-o-help/
have you tried just resetting the BIOS? i had a X99 board from ASUS that would sometimes just randomly not post. but when i reset the BIOS it would post again no prob.
https://linustechtips.com/topic/1015634-lil-bit-o-help/#findComment-12140017
